最新報價
我舊年平安夜(2010-Dec-24) 死車搵的士大佬幫手都係收我 $70 !!! (我由$50叫起)
I needed a jump start last sunday AGAIN because I need to use notebook inside my car, I used a 12V transformer to charge the notebook.  I thought it did not consume much of the battery power, but finally the battery was flat again!!!!!!!   This time, I learned from C-hings, I paid $100 to a taxi-driver to jump start my car, but the taxi-driver was not so familiar with the jump start because my car could not be started after connecting the cables correctly.  Then I called my sales again, he asked me to turn on the headlights to see if the connection was good or not, but the headlights could not be turned on, then the taxi driver shake the cable slight to make them bite tighter, it finally workded.
Learning experience:
1) when you use those 12V note book transformers, beware of the flat battery consequence
2) when you work in your car, turn the room lights off.  I think one of the reasons why the battery turned flat so fast (in 2 hours) was that I kept one of the side doors open, it would turn the room lights on, but it not noticable during a sunny day.
3) I bought the emergency battery on this Monday because: a) ask somebody to help is timing conusming and costly; b) a better reason, it can provide two 12V plugs for my 12V notebook transaformer and other devices, I do not need to run the engine (which save $ too)  in order to aviod a flat battery if I work inside my car.   It has lights and pumps too.
It's size is not so large comparing with my RJ1's trunk, I like it.
The above is my experience and would like to share with my c-hings : >
Dear Friend
I needed a jump start last sunday AGAIN because I need to use notebook inside my car, I used a 12V transformer to charge the notebook.  I thought it did not consume much of the battery power, but fina ...
Mydearfriend 發表於 3-3-2011 23:35
If your engine is not running, flat the battery in 2 hours is not fast la......
Just a little tips for your emergency battery, if you want it has longer lifetime, always keep it fully charged.
其實除左notebook, 好多人會charge手機, psp, notebook....或者你真係有需要.
不過我始終覺得以上既用品都係響屋企charge好D. 因為車係要靠電開動,
行車時已經有好多野係要用電. 所以行車時charge回電池既電 遠 ...
掌摑王 發表於 3-3-2011 23:55
You are damn right.....
